UK Gearmuncher wrote:
1. I'd already stated earlier that a runner may get some level of gain but again, the literature does not say its guaranteed and the amount you'll get is highly variable. There is at least one study that showed a zero benefit. I think we're broadly agreeing though on this one but you kept shifting your terminology in your rebuttals (e.g. such as synonymously equating energy return to speed) and as someone who operates as a scientist in this field, that had confused me when I'm replying. (note: The Kipp study is good - plus I rate co author Roger Kram in this area - but that NY study would never get past peer review - it's riddled with flaws)
My comment was about efficiency and did not use "energy return" until you did, which confused me.
I also have advanced degrees and worked in academic/federal research for 7 years as a scientist/engineer before my current role, so I'm no stranger to working with measuring equipment, data processing, and the variables between. Seems we're still able to confuse each other. :)
But your statement "literature does not say its guaranteed and the amount you'll get is highly variable" was the basis of my post saying that you need to do proper testing to really know the benefits and which shoes work for you. An outdoor test using Stryd/HR/TPE is not that, and Nike might make the slowest shoes for you specifically (in response to "just get Nike" posts).
Since you said the shoes are designed for certain types of people (50kg 2:00ish pros), I also wanted to highlight that someone like me (85kg 3:00ish amateurs) can still find 4% efficiency gains between shoes.
