I'm not a power meter expert, as my subsequent questions will display. I'd love input from folks who understand the instrumentation and/or the engineering-human interplay better than I do. Bonus points for expressing confidence level of answers. I know many of you have amassed huge quantities of time thinking and writing on similar topics and I am grateful for your time if you choose to answer any or all of these.
(My assumption is that the answer may vary for many of these questions, depending on the make/model/type of power meter.)
Implications if force or torque cycle frequency-based cadence calculations are used by any given power meter, related to number 6 above:
This would result in power reporting that, as a percentage, is half the rate of change in cadence lower during an acceleration. Correct me if I'm wrong. Similarly, if sprinting uphill after a hard leadout but slowing because of high drag + high grade, power calculation would be erroneously high by half of the rate of change in cadence.
Here is some real-world data from two days ago on Zwift, if they're using a simple torque cycle frequency calculation, rather than a faster sampling rate for cadence calculations.
Fun fact re: Zwift: after this sprint, they continued to accelerate my character for 2 seconds after my power had dropped to 0, on flat ground. Fun times in data smoothing in software / UI land. :)
Dr. Alex Harrison | Founder & CEO | Sport Physiology & Performance PhD
📱 Check out our app → Saturday: Pro Fuel & Hydration, a performance nutrition coach in your pocket.
Join us on YouTube → Saturday Morning | Ride & Run Faster and our growing Saturday User Hub
- My understanding is that power meters measure either torque (force about an axis) or uni-directional force (up and down by use of a strain gauge or piezo electric crystals etc), and they measure cadence. Then, the power meter calculates "power" my doing some quick multiplication and sending that calculated variable out for display on a head unit, right?
- My understanding is that they calculate and report power every 1 second to the head unit. Is that correct?
- When during the pedal stroke do they measure force or torque? Surely it's more often than every 1 second. What is a common sampling rate? 100Hz? 1000Hz?
- Do they aggregate the force data by averaging it? Or do they use the peak force? Median? By what mathematical process does the power meter decide what force or torque number to use in the calculation to produce the number sent to the head unit as it's single "1Hz power measurement." (assuming I was correct in question number 2 above)
- In the case of systems measuring just force and not angular force (torque), as I believe is the case for pedal power meters (using piezoelectric crystals?), do they use the same averaging or force data selection method as used in systems measuring angular force? Surely not. I hope not. I won't be surprised if the answer is yes, it's the same and we're all just accepting it.
- When does a power meter measure cadence? High sampling rate aggregated in some way like force or torque is? Or just based on the cycle frequency of the force data? If the latter, the implication is that during system accelerations where cadence is increasing, power calculation will actually reflect cadence that is half a pedal stroke behind what it is if it were being sampled at something closer to continuously. (ie. 100Hz or 1000Hz). See implications and data below.
- What effect does temperature have on force or torque measurements? Thinking about climbing Mt. Lemmon starting at 4pm, for example. Or in cases of overnight riding during summer in arid environments where temp swings can be 30+ degrees.
- Safe to assume pedal-based power meters do not measure power added by pulling up on the pedals during a sprint?
- I usually see discussion of power meter error expressed in terms of it's error in the 100-400W range (around most human's FTP values). Usually expressed as a percentage. Does that percentage grow as power increases? Does it grow systematically as power increases? Or does it grow idiosyncratically to the individual as they approach max 1-second power efforts? Both? By what magnitude? How do you know this?
DrAlexHarrison: Mar 8, 24 3:26
