Kat_Kong wrote:
Hi everyone,
I am looking to upgrade an ancient Giro aero helmet. My existing helmet has zero air vents and I have over-heated wearing it in longer races. I would like one of the new helmets that has a removable visor.
What are your recommendations?
KK
A buddy of mine recently came over to do some tests.
Aero and heat were both considered. When he overheats on the bike, the is throwing up for 42 km. He would do 2km out and back tests, just over IM pace and would be drenched in sweat with one of the helmets.
We tested the Aerohead that I owned, P09 he owned, old Giro A2 he owned and a Vanquish.
The Aerohead was the fastest by almost 8watts at IM speed. The P09 was a bit slower. The A2 was closer to the Vanquish so was eliminated.
He then took all the helmets home and tested for how warm they were. He found the P09 too warm, not enough air flow.
At the end he chose the Vanquish in full consciousness he was giving up 8watts. On a cool day he would have used the Aerohead.
I wish we would have tested an Evade but I suspect we may have closed the gap to maybe 5 or 6 watts.
So if heat is not an issue, go with the advice of testing and if you can't test go with the one most often fastest. Few people are slow with an Aerohead.
If heat is an issue, be conscious of what you will most likely be giving up.
BTW, he loved the Vanquish visor since that is one of your criteria.
