rruff wrote:
That's fine; with temperature measurement I should be good. Oh, except for humidity. The phone is a bad place to get that since it's in front of my face. The WM is better. The station measurements are pretty useless where I live since temperature can vary easily 10C over a few miles, and humidity varies a lot also when there are random thunderclouds around.
No problem, I will move WM relative humidity to the first place.
rruff wrote:
I'd asked you earlier about lap lengths being off, but using 1.003s time steps and using the first data point in the next lap appears to have fixed that. For instance I'll tack on the first data point of lap 6 to the end of lap 5. Since "fixed lap length mode" is set up for continuous laps I thought this would be correct. Does that sound right?
Yes it is right. The app computes the average time between 2 ANT+ messages and it is not 1.000s. I saw, by comparing the files, that bike computers (eg Joule 2.0) repeat (dt>1s) or discard (dt<1s) a recorded value after a long time when trying to record every one second...
rruff wrote:
Regarding auto zero. With my Powertap the "enable auto zero" is not supported.
In fact, that means disabling autozero seems not supported. Strange, it is possible on a PT. I don't see that on my G3...
rruff wrote:
"Enable app autozero" seems to work except that I see messages on the screen that indicate the request for calibration is sent at odd times, so I don't know if I can trust it. So I've been disabling auto zero and doing a manual calibration.
The app autozero was a try to monitor zero offset as I suspect my PowerTap zero drift was the main issue of the poor CV from run to run during my aero session. So, I implemented an algorithm to send a manual calibration to the PM when conditions (criteria) were satisfied during few seconds: no power on pedals, no cadence. Each time a zero was done, the PM sends back a zero offset value, which appears on the screen and is written in the logs. I am not sure the criteria is the same than the PM auto zero strategy, so I would not recommend to use this feature (I will suppress it soon). But at least, it confirmed me that the PowerTap zero drift was the issue of poor CV from run to run (eg: aero session during early morning when temperature rises quickly), cause even if the zero offset is done between each run, the zero drifts during a run of several minutes when you don't stop pedaling...
rruff wrote:
That's fine, but I notice the power field on the screen sometimes says -0 and sometimes 0. Is there some significance to the minus sign?
A minor bug in the app, -0 is because when smoothing power is computed on several seconds, roundoff error may give a slight negative zero. I will fix.
Blog |
Twitter|
Bike CdaCrr app
