lcparlatto wrote:
Hello!
Both are high-end bikes, I don't think you can go wrong with neither of them.
I've moved from a 2013 Cérvelo P5-Six to a Trek SC SLR7 P1 this year. I'm very happy with the bike, performance wise it is very similar honestly, the obvious differences are the disk brakes and the wheels running larger tires (which I'm really enjoying btw).
Thinks to consider that might help you choose:
- Crank arm length, the SC only comes with 172.5mm if I'm not mistaken, check with your LBS, I replaced the Shimano one for a Rotor ALDHU 165mm. Maybe Canyon has more options.
- With Canyon you have the chance to get extended arm pads, for the SC you may need to look for Tririg scoops or other and this may limit the BTA usage. Although they are not cushy the flat bars works as extended arm support for me. (hint: Cee Gees makes outstanding cushy pads even for this SC pad).
- Both wheels are great! However I had the chance to choose between the RSL 51, 65 and 75 without affecting the price (I've chosen the 75 front and rear), so you can probably choose the profile you prefer.
- Race setup, with the Trek BTA you can also add another bottle above the BTA bottle. It is nice although I don't see many people using it (I use it). Heard a pro complaining that on some descends, Nice course, it affected the bike stability.
- Trek frame aero bottle, it is great, it holds +-750ml however just like any other aero bottle they are not thermal. They slide in and out easily, but if you don't like it you can switch for one or two bottle cages of your preference.
- The SC internal storage I could only fit these TPU/Latex tubes. A standard butyl one I have a really hard timing fitting it together with the fact that I could potentially damage the tube. The Canyon one looks much "easier", but I have no experience.
- The SC top tube storage (bento box) is big, you can fit bars, gels etc. and can be removed easily to clean.
- I can't say much about the ISO speed, but it is a very enjoyable bike to ride.
- A friend had issues with a plastic part that holds the straw on his CFR, he that to import it from Germany and the shipping + taxes were way more expensive than the spare part itself.
Thanks
Nice write up
Ended up going the trek , no real reason just mainly due to the lbs in case I need them
I have a couple of canyon bikes ,while they are great , ordering the bike itself and then getting parts or changing bits is never simple
I have a aero coach aero bar set up coming that’s made fir the SC so it will be fitted at the shop so I’ll never deal with the standard bar that a lot complain about
