As a christmas present, I got the Nashbar T3 Fluid trainer. This is my first fluid trainer. I was previously using a minoura Mag trainer that I borrowed from a friend. The thing I noticed is that the fluid trainer is much more difficult than the mag trainer. It is great that it has a very large resistance band, but in order for me to achieve a cadence in the 90's, I have to use very low gears on the bike. I have a couple of spinerval videos and I can't even come close to the gear ratios that are called for. The biggest problem is that I can not gear down during rest intervals.
What type of cyclists are these fluid trainers designed for, in otherwords, what cyclist would be comfortable on a fluid trainer in a middle range of gears, just spinning at 90 rpm's? Personally, I am around a 21-22 mph 40K TT on a flat course.
There are several things I can think of,
1) this is a cheap trainer, so the resistance level isn't the same as say a cyclops
2) I have been riding the mag trainer for a few months now (exclusively, no outdoor riding), so my legs aren't used to this type of resistance.
3) I have the resistance wheel pushed too hard against my tire, making the rolling resistance larger than normal (I have a tough time knowing when to stop, it seems that my wheel slips a lot if I don't have it pretty firm)
4) This trainer is designed for better and stonger cyclist.
Are any of these good explanations, if so, which ones? Thanks for the help
"What the mind can conceive and believe, the mind and body can achieve; and those who stay will be champions."
