grumpier.mike wrote:
...the utility comes from really understanding how to use it properly.
Good software and a test venue and protocol that leverages VE.
Yup. I have tried doing the outdoor Chung/VE method a fair amount and the combination of little to no traffic and calm conditions makes it really difficult where I live. While the Notio does a lot of stuff, if the wind sensor makes outdoor Chung testing possible it will be worth the cost. Just the fact that it has a built in air pressure sensor for automatically measuring the altitude corrected tho value goes a long way to making it worthwhile. A Weather station to do that costs half as much as the Notio.
Altitude corrected tho value? Air density? The pitot measures dynamic pressure directly, so air density is not needed.
If you have passing cars then that's going to mess up your data. Based on what I've seen with similar sensors they won't be able to accurately measure what your bike/body sees when that happens. So I think we are stuck with that restriction.
Dealing with wind is what we hope to get from an aero sensor. Plus software that uses good test protocols and lets you analyze data in the field. Real time data will inherently add extra error vs a good protocol. At the current state of the art (AFAIK), it's not worth trying to use real time data for field testing.
The best protocol IMO is a out-back where you ride close to the centerline and can mirror the runs in both directions. This lets you check for wind bias; a small error in that causes a big error in your CdA result. Also, after a few runs you can nail down the actual elevation instead of treating it as an unknown, which is another nice feature for error checking.
Last year I used the CdACrr app and anemometer, and I think it works better than anything else I've seen. Cheap too. I was hoping to motivate Pierre to code an outback mode... but with 2020 a bust and this being my last year racing, I lack incentive...
