IronManny wrote:
Fresh79 wrote:
I sent mine back as they’re not compatible with mechanical unless you want to drill holes into the extensionsor is it just wrong that internal cable routing with mechanical shifters work
That was the solution proposed to me by the distributor in Australia when I raised the issue with them. My LBS also could not see an alternative without drilling holes unless you want to run the cables outside of the extensions (on the underside)… but why should you on a top tier set of aero bars?
On top of that, the mech cables need to come out of the extensions and out of the space where the arm pads sit. There are grooves for Di2 electronic cables to neatly sit, but the mech cables are thick and less flexible that electronic cables…
