Ex-cyclist wrote:
Slowman wrote:
Ex-cyclist wrote:
FWIW, a 30mm external and 23mm internal will contain a 28mm tire inside it's profile. But just barely. ERTO standards say you shouldn't run anything on a 25mm hookless rim narrower than 29mm. I think there is just too much being given up there (illustrated by the data Marc found) just so the manufacturer can save a couple of dimes per rim.is this no longer current?
FWIW i put my wife on shimano wheels, in some part because of hooked beads. i don't trust her to always use the pressure gauge i have her when she inflates her wheels. one very real - and in my view the only - drawback to hookless are those who just don't understand the pressure restrictions and aren't likely to focus on them in the course of their riding.
It is not current.. I can't find the current chart, but this info has been in the public domain for a while now.
https://www.cyclingweekly.com/products/is-the-bike-industry-divided-over-new-tyre-and-wheel-rim-size-regulations
Your last point highlights the issue with hookless. We're relying on people to understand tire pressure and know that they have hookless rims. I'd wager a great deal that more than 95% have no clue if they have hookless or hooked rims. It's a slog to get people to actually lower the pressure in their tires, as most think the MAX pressure is the recommendation. I'm sure the first time someone puts 100PSI in their tire on a hookless rim and coats themselves and living room with sealant, the'll probably get it, maybe. But only after coming into the shop and complaining their wheels are defective.
As Marc mentioned, if you're going for max efficiency and Crr on relatively smooth roads, that is generally outside of the operating window of hookless for everyone save many women and a few small men. <60kg. Do they work for you? Sure, and that's perfectly fine. But being near 82kg, I'm not willing give up those watts just yet.
thanks for the update. i hadn't been paying attention. i'll need to put a note on our hookless wheel/tire compatibility database. i'll need to check with zipp and enve on how they see it should be worded because it appears there's a disagreement there and i need to look on zipp's page to see what they're recommending on their compatibility chart.
none of it matters to me because i'm all in on the 5mm delta. my absolute favorite road wheels to ride in all conditions are zipp 353 NSW and cadex allroad. but i ride them both with 32mm tires.
as to your 95 percent characterization, are hookless placed on OE purchases today? almost nobody buys a zipp 858 NSW and remains naive to the pressure restrictions. as to my own riding which starts at 28mm, in my own field testing, which is just for my private riding, there is no case where more than 65psi is ever in my tires because beyond that pressure the system begins to slow down. i weigh 77kg.
i would be really sorry to see the hookless rim go away. but i'm not at all sorry that hooked rims remains.
Dan Empfield
aka Slowman
