Just fwiw, Extralight has some really explicit taping instructions for those rims, and there's little to no mention of this in the vid other than "taped by expert". From what little is visible in the video, it sure looks like the tape is a bit narrow for that rim, and he never mentions checking either the width of the tape or that the thickness meets the total of .3mm required by the manufacturer. Judging by the fact that they mention the tape requirements at least 1/2 dozen times in the one page tech sheet for the wheels (with big yellow warning graphics) they think this is pretty important, so it strikes me as odd that it's not really considered in the vid.
That's a lot of tape, by the way. It's three full wraps of something like Tesa 4298. I haven't measured the Schwalbe tape, but I would imagine you aren't going to hit that thickness requirement with the one wrap of tape that Schwalbe says to use in their own installation docs.
That big Topeak charger pump in the video is also worth noting. Extralight explicitly warns of damage if more than 5 bar was used in initial beading of tires, and if he used that thing it absolutely was. Reading between the lines, using a charger pump or compressor on these wheels will actually void your warranty, which is pretty unusual.
It's definitely a problem that you need to dot all the "I's" and cross all the "t's" with some (or a lot) of the tubeless stuff out there these days, but you do still have to, especially with the more exotic offerings like these Extralight wheels, which... I mean, the name kinda says it all, doesn't it?
Coaching and bike fit -
http://source-e.net/ Cyclocross blog -
https://crosssports.net/ BJJ instruction -
https://ballardbjj.com/
