danen1973 wrote:
What case are you resting here? Is this a courtroom? Someone on trial?
I was looking for help here and not remarks that do not help me. Some responded with suggestions and I appreciate it. You James Haycraft didn't really help. Do you even own a P5?
The point I was trying to make here is the aluminium is corroding around the screws. One poster suggested that I back out the screws (I think there are about 12 screws) once a month and apply some solution that would prevent that. My issue is that i can't take out some of them because the head is stripped. I was looking for assistance here. I also found it odd that they would design an aero bar that would, as part of the regular maintenance, require one to back out the screws every month and "lube" them. How many P5 owners do that on regular basis?
The issue with rusted screws is completely different. How does one prevent screws from rusting?
I did help you, I pointed out to you an issue that you can keep in mind heading forward during your ownership of bicycles. You cannot simply leave the bicycle unattended to maintenance-wise. ALL of the bolts on the bike should be checked routinely (this is also in your owner's manual). Your brake cover bolts rusted because you sweat and sport drink'd all over them and then didn't wash it off after a ride. This is the same reason your cockpit bolts are fused and consequently you have stripped the heads on all of them.
I owned a P5 for 3 years and then sold it in "like new" condition because I actually treated it with care and respect. Most triathletes treat bikes as you do: poorly. I also sold, fitted, and worked on a great many P5s (both the P5-3 and the P5-6).
EVERY SINGLE TRI BIKE has a multitude of bolts in and around the cockpit area. EVERY SINGLE ONE OF THOSE BIKES should be taken care of in the same way I have detailed here. Yours is just a multi-thousand dollar cockpit; it's no different functionally from a $100 aerobar setup.
It's just laughable that people blame the bike for issues that they could have prevented. Your bike hates you.
