someone had to start it...
FYI
Notes on the bike.....
Steering radius is limited. No full lock to lock. The fork and frame have a matching groove/pin to limit the turning radius.
Good --- no more steer tube to frame nicks. eliminating any damage to frame.
Bad - will have to make wider turns especially at hairpin situations.
Bike comes pre-wired, so if you want to upgrade to di2 at later point you will have to be creative since there is NO access thru the bottom bracket shell. There is a BB liner (not removal)
However, there is an "access port" in front of the BB shell.
When time to install new cables and cable housing - You must leave behind some sort of "fisher wire" as you remove or re-rounting cable housing may be impossible - very time consuming. Again because of no access thru the BB shell.
Waiting for internal battery harness for my original di2 (10 speed, non e-tube) before I start my custom Serios S build out.
Decided on the S version because of simplicity of front end adjusting and I resale value of bike when time comes. I will not be cutting the steer tube.
Steer tube must be cut to size when using the DB TT stem.
Waiting to hear if TriRig Omega brakes are compatible with the frame.
will be updating photos as build progresses.
the start and break down.
Retul Certified Fitter. gebioMized Pressure Mapping http://www.PedPowerPerformLab.com.
Retailer of Wahoo Fitness, Sable Water Optics, Enve Composit, Giro and more.
Zone3 USA Ambassador - use code DEAN25 for 25% off
http://www.OasisOne-Twelve.com - The ultimate hands free hydration system.
https://www.athlinks.com/athletes/19354499 - results.
FYI
