Ian,
Again thank you for your time and the interesting advice.
So you confirm that I need a size L instead of a size M that was recommanded by Canyon's PPS. I understood that it is because with the M size it is not possible to achieve the Y 666mm that I need. Do you confirm ?
Consequently, I will follow your recommandations and go for a size L, flat bar (I prefer the estehetic), short stem, 60mm spacer and the TSP. Just to clarify, on my case the TSP is used to move back the pads, do you confirm? Could you precise as well how many milimeters back?
I didn't find any clear description of what has been changed between the 2018 and 2019 slx versions. I understood by reading previous posts that it was the cockpit and notably the pads position. Could you confirm and complete if I missed something else. For my fit, which version you think is the better ? I would be curious that you flesh out the 2019 version just to compare.
Wil
Wil
