Hey everyone, Eric Reid here, FIST certified full-time bike fitter here in North Carolina.
I'd like to start this thread in conjunction with Cervelo to help prescribe the right bike for you. You may have noticed a couple of new offerings from Cervelo, not to mention three interoperable mono-risers to fit the two new bikes. This thread will help you select not only the right size frame but the right mono-riser and front end configuration including basebar configuration, riser type, riser height, pad width, pad tilt (or not) and extension shape. There's a lot going on here and you have a lot of options.
This thread is about *fit*. Your fit. I want you to be optimized... comfortable and powerful and ready to put down some fast bike splits based on a good position on the right size bike. What I won't be talking about is availability, customer service, comparative aerodynamics, the pros and cons of high hands and short cranks, or maintenance. There are other threads here on the forum for that, and you can also contact your LBS. For information on the new P5d, see HERE. For information on the new P3x, see HERE. And for information on the new mono-riser systems, see HERE. You can also reference the P5d and P3x threads on the forum as well.
Rules of Engagement for this thread is to post your Pad X and Pad Y (pad stack and reach), and if you know it, your Pad Z (pad width) as well as the bike that you're interested in. Remember, we're measuring to the *back* of the pads for these bikes. If you're not sure which bike, let's talk about what you're going to be using it for and go from there. If you're not sure about your fit coordinates, I'll walk you through it. If you're not sure your fit is a good one, I'll try to recommend you a competent fitter. Fit coordinates from a fitter will yield the best results in prescribing a new bike.
OK, so Pad X, Pad Y, and Pad Z to back of pads....
Let's begin.
Eric
Let's begin.
Eric
