Quote:
Ian.
I was last fitted (FIST) at the end of 2010. I haven't changed my fit since then. (other than replacing my saddle - Specialized Sitero)
I do think I could now go lower, but I am unsure by how much. Current dimensions on the bike - 2011 Argon18 E112
Pad Stack 735
Pad Reach (centre) 449
Saddle Setback (to nose) 65
Drop - 70
These were pulled off the current bike, but I won't claim they are fully accurate.
Picture in use attached.... UCI legal, which is a requirement, and still needs to allow me to run after
Any chance I might fit on either of the current Canyons?
Cape_Horn,
Short, Quick Answer: if you're going to stay with Pad Stack of 735 and Pad Reach of 449 then you'd need to be on the Canyon Speedmax CF in a size large but you'd need a shorter stem than the one that comes stock on the large. But, that set up would leave you in this position which I'm not happy about so let's go to the longer answer for as it's a far better one.
Longer, More Valued Answer: Everything about pic says "up and back" to me. That bike you're on has a seat angle of 76 degrees and you're on a road saddle (comfort is found rearward) so your hips are behind the bottom bracket in a such a way that it's forcing your cockpit to be short and your arm pads to be high - that's confirmed in the fact that you've got the tallest 3D headset top cap thingy + what looks like another 20mm of spacer + a +6 degree stem. Now, what might save this whole position is the new saddle because that new saddle might allow you to sit farther forward and give you the position your need/deserve but the question is - did the new saddle result in you flipping that stem (-6 degree), stripping out that 20mm spacer, maybe even going to the shorter/shortest 3D top cap, and moving the pads out or going to a longer stem? If, not - if you have the same front end set up with then new saddle then not much has changed.
You can be UCI legal and be in a comfortable (top priority), powerful (second priority), and slippery (third priority). A better position on the this bike will help you get there....also, a more modern bike with better geometry will help you get there.
I'd like three things from you if you can get 'em for me: 1) where do you live (city). 2) I want your overall height and 3) I'd like your saddle height measured from the center of the bottom bracket to the top of your saddle in the middlish. Get back to me with that and let's continue this discussion. #1 is cause if one of the fitters on "my list" is near you then I'm going to urge you to go see them. #2 & #3 are in case you are too far from a great fitter then I want to propose a Pad Y/Pad X that is far closer to where you could be.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
