Re: Has anyone moved back to a longer crank? [Hanginon] [ In reply to ]
Hanginon wrote:
I am not a believer in the instant "Ah Ha" moment other's have commented on, but rather, a believer in how something feels after many miles and time in the saddle. Only then, IMHO, can you really pick up on ALL the subtle ramifications (good and bad) due to a change in position.
In my case, it was instantly noticeable. I have limited range of motion in my left leg from an old accident, and 170mm cranks are right at the very limit of what I can ride. 172.5s (which are what normally come stock on 54cm/mediums) are slightly outside my range, and painful to ride, even in an upright position (I can't quite get over the top of the stroke, and can just barely manage with 170s). Switching from 170s to 165s gave me a bit of breathing room. Comfort, plus a slightly flatter back, just by changing the crank and raising the saddle 5mm. My very first ride, I was faster and more comfortable...
"I'm thinking of a number between 1 and 10, and I don't know why!"
Re: Has anyone moved back to a longer crank? [s13tx] [ In reply to ]
s13tx wrote:
Hanginon wrote:
At 5' 7'' you probably should not have been on 172.5mm cranks, even prior to the "short crank" revolution.
I didn’t know any better.
What puzzles me, and what the esteemed Hanginon is probably referring to, is that someone was selling small-sized bikes with 172.5 mm cranks.
"FTP is a bit 2015, don't you think?" - Gustav Iden
Re: Has anyone moved back to a longer crank? [ericMPro] [ In reply to ]
ericMPro wrote:
mathematics wrote:
I'm of the opinion that pros are running 170-175 because that's what was available when they started riding. Short cranks only became widely available in the past few years. Even in this thread there's evidence that the favored (not best, favored) crank length is the one a rider has spent the most time riding. One expects this to hold even more true with riders who have thousands of yearly hours stacked up.
All but the very smallest frames still come with 170mm. This is slowly changing. It's just out of proportion that a 6.5ft rider should run 175's and a 5.5ft rider (18% smaller) should ride 170's (3% smaller).
I think the prevalence of shorter standard cranks will show up as shorter cranks in the pro field in ~10 years.
Yes, three phenomena:
1. Elite athletes use what’s available
2. Elite athletes use elite crank lengths
3. Elite athletes are the last to know
E
I fit the US womens road race champion a few weeks before the race last year. She had 165mm on her road bike. I recommended 160s but no big deal. On the fit bike for a time trial fit she strongly preferred 145s, as most riders with sub 650mm saddle height tend to choose when in aerobars. Her team gave her a tt bike with 170s a week before the race. She bought (her own funds) the shortest thing she could buy that honored the sponsorship.... Shimano 105s in 160mm. We gave up 4-5cm of drop from the fit bike position. 1st in the rr, 5th in the tt.
Re: Has anyone moved back to a longer crank? [FindinFreestyle] [ In reply to ]
E
It’s a real mystery to me why the industry specs what they spec, and why it never changes.
People come to me for TT fits with German bikes that have 175mm stock!!!
E
So a crank that was 15 mm longer (160 vs 145) forced you to raise the cockpit / lower the saddle by 4-5 cm?
Re: Has anyone moved back to a longer crank? [kajet] [ In reply to ]
Yes.
I can't think of any new TT/Tri bike that will properly fit anyone with a saddle height less than 650mm.
Re: Has anyone moved back to a longer crank? [mathematics] [ In reply to ]
[/quote] If I put the 170's back on, it feels better with a much more balanced effort feeling between my thighs and calf's, and my legs feel better overall after the ride.
Has anyone else noticed this?[/quote]
Yes! Back about 10 years ago when short cranks were a new thing on ST, I went from 170's to 155's (I think). I tried it for a a season, not terrible. However, after the race season I was using an older TT bike that still had 170's on it, and just felt SO much better. Power, rhythm, feel throughout the power phase, just clicked. Never looked back and use 170's now. For info, I moved my seat height all over the place with no big difference. I also used to ride fixed gear on the roads, for that 165mm cranks is what I use there: right tool for the job in that case.
I have been planning on going from 165s to 175s since last summer but didn't get around to it. Finally switched over this weekend. My desire has been to lower centre of gravity for descending as I had a few speed wobbles and twitching moments. Otherwise, I have been very happy fit wise.
Did an easy zwift 30min ride before and after switching. 1 hour time difference between spins. Went up the climb portal. Some anecdotal evidence and some caveats below.
My average watts increased 146>153w while my HR was lower with 175s. I would not take these results as 100% accurate as I use garmin vector 2s and I find them sensitive to the torque they are installed at. But I would confidently say there was no real impact in my power/RPE switching to 175s. This may be different riding at higher wattages and struggling with the more closed hip angle.
What I thought was more interesting is that my self selected cadence was higher (86 vs 79) with the 175s than the 165s. Completely counterintuitive but I'll monitor this over the next few rides.
All I did was lower the saddle, I didn't mess with fore/aft position. Felt good riding in the position but one thing I did notice was a bit more rocking in the hips.
6'5" here, never got rid of my 175's.
Re: Has anyone moved back to a longer crank? [Dudaddy] [ In reply to ]
Nice! I was wrong about my earlier "Ganna" comment. At 6'4" tall, he used 175's to set the new Hour Record.
Besides my move back to 170's (from 165's), I also started moving my foot back on the pedal, as opposed to slamming the cleat as far rearward as possible on the shoe. I'm essentially back to the position I rode as a young man - and it feels good.
I'm starting to think that much of what is currently thought of as "good position" is negatively influenced by Triathlon - they are in fact two different disciplines. Tri riders need to be more comfortable since the ride is longer, and they need to run when they get off the bike. TT rides are usually one hour (25 miles) or less, and you should be in so much pain that actual "comfort" is completely secondary - plus if you did your split correctly, you might not even be able to walk when dismounting!!
Unfortunately, the number of riders who specialize in TT's who get "fitted" is probably a very small percentage vs Tri riders.
Re: Has anyone moved back to a longer crank? [ In reply to ]
IM 70.3 PucĂłn, Sam Long blasted the course record with 175 mm cranks.
Re: Has anyone moved back to a longer crank? [Osciozo] [ In reply to ]
Was he on 165s previously?
Re: Has anyone moved back to a longer crank? [retrying] [ In reply to ]
This thread has been really informative.
FWIW then at 6'4" and all legs (body of a 6 footer) then I ride 175mm on road and my tt is 172.5mm. For full disclosure US12.5/48 feet. But, my natural cadence is 96-97rpm and has been for over 20 years, going higher if I'm doing high power stuff. On hills I'll almost certainly spin rather than stand - and whilst I'm not CAT A racer, then I am very much mixing it with the wiry mountain goats on the club climbs, albeit using a totally different approach. The biggest leap forward in my cycling came from a move to a compact chainset as that meant I had more appropriate gears for my cadence.
And so noting the talk about the logic of smaller being to help the cadence increase means I am even less inclined to try going shorter.
Re: Has anyone moved back to a longer crank? [Duncan74] [ In reply to ]
Cadence can be controlled by simply changing gears.
Re: Has anyone moved back to a longer crank? [jimatbeyond] [ In reply to ]
Gears can be changed to keep power and cadence steady
No, it’s not that simple. Unless you want force to increase significantly, cadence must go up proportionally to the crank arm decrease. If someone likes a cadence between 95-100 and they’ve been using 175 cranks, if they switch to 165s, then their cadence will have to go up to 101-106 to keep force the same. A lot of us who are pushing their limits already with force cannot increase it with shorter cranks without muscle and joint pain.
I’m planning on going back to 165s after about 10 weeks on 150s. This thread has been manna for my soul. I’m 6’5 with long legs (37-37.5 inseam) and mostly been on 175s and 172.5s for the last 20+ years. I made the switch to shorter cranks after some reoccurring back issues and not stellar range of motion with hip extension. I was feeling pretty good on the 165s but decided shorter is better and swapped over to 150s after a dynamic bike fitting.
First impression was the cranks felt like a toy bike. HR was elevated at similar speeds/power, because my cadence had to be 105 rpm to maintain similar force as 90 rpm on 175s. If I averaged lower than 103 my quads and knees would get upset very quickly. I was able to get a flatter back but my body has not been able to adjust to that, or maybe it’s all the extra weight on my pads due to the shorter cranks not supporting my upper body as much, but now I have really bad thoracic spine problems - spasms, strains, constant soreness that has also made swimming a big problem.
So to summarize 150 cranks subjectively feel bad, I’m slower than I was before, and any “improvement” in bike positioning has created more problems.
Swapping back to 165s after this weekend and will reevaluate after a couple months. Obviously terrible timing in the middle of the triathlon season, but it has to be done at this point. My hip flexion and other flexibility markers have improved with a lot of body work, so it’s possible that I may be able to go back to 170-172.5s, if not 175s.
No, never rode better in TTs or road before going 165. See shimano is about to ship 160s next mth. No need there but very happy with 165 and will send my last 170 crank to a new home.
-U
Re: Has anyone moved back to a longer crank? [thatzone] [ In reply to ]
No, never 165.
175 > 172.5 > 175
and may try 177.5 over the winter.
Magnus on 172.5
Rudy on 175
Folely about to jump to 175. Was on 172.5 at Chattanooga.
Pohl now on 175
Will do another Performance process podcast with Ronan on this topic soon. Discuss some of the points here: https://wovebike.com/blog/bikefit
wovebike.com | Wove on instagram
Re: Has anyone moved back to a longer crank? [Nick @wovebike] [ In reply to ]
Thank you, this is interesting. Notably von Berg is if course 188 cm or 6 ft 2”, Ditlev is 195 cm or 6 ft 5”, and Long is 193 cm or 6 ft 4”. Pohl 186 or 6 ft 1” and Foley is the smallest of the bunch at 183 cm (but he’ll come around to shorter cranks).
Looked at the blog. Imagine if history shows that very short cranks were the curse of the truncated nose saddle! :-)
Spent decades on 175. Worked down to 165 and after 2 or 3 seasons back on 175. Regret not doing it sooner. Toying with trying 177.5 but haven't tried them yet.
___________________________________________________
To go faster than ever before, visit: https://squareup.com/...mic-high-performance
Re: Has anyone moved back to a longer crank? [QKRTNU] [ In reply to ]
What’s your inseam?
