Anyone know if the wider floor as 77 will fit in a gen 2 speed concept?
It should work. I run 26 external and there's still room to go wider. You'll have to remove any washers in the inside of you brake pads and adjust brake limit screws out.
Probably limited to 28mm tires.
If you didn't figure it out, I run a 77 AS on mine, no problem. Just the front, I run the old flo A/C disk wheel. Corsa Speed 25 and GP5000 TT TR 28 fit.
