Re: Factor HANZO TT bike [Pwraddr] [ In reply to ]
I wish I didn't have to, but I need proper hydration for my IM ...
Re: Factor HANZO TT bike [pjadidi] [ In reply to ]
Hi - Candice here from XLAB
The aerobar setup that comes with the Hanzo unfortunately is not compatible with the Torpedo Versa. That model has brackets that fit on round extensions arying from 22.2 up to 27mm diameter.
You might be able to get away with a Torpedo Mini Mount - this is a narrow mounting plate with 4 velcro straps - but I would need the dimensions of the flat extension area in order to see if the straps would be long enough to wrap around them.
Candice Turner
CEO
XLAB - Aerodynamic Triathlon Accessories
Dawn to Dusk - Off-road Specific Storage Accessories
http://www.XLAB-USA.com http://www.dawntodusk.bike
Re: Factor HANZO TT bike [Candice - XLAB] [ In reply to ]
Thank you Candance. After going back and forth with Keith in your costumer relations department.here is what the bike mechanic and I figured we need to do :
Use the plate (only) of your versa system. Turn it 90 degrees Shape it properly so it is straight, then use it a abridge between the two aero bars ( bolt on each bar ) and bolt the entire versa 200 on top of the bridge .
Once this is done, i will send Keith a picture so you can keep it for future reference.
Oh awesome- glad Keith and your mechanic could figure out a solution! Looking forward to seeing the pic!
Candice Turner
CEO
Took xlab versa base plates and some DYI
