Quote:
Hi Ian, thanks for all your help on this thread
I'm looking at CFR/CF SLX
Height: 173cms
Inseam: 83cms
Pad X: 425mm
Pad Y: 610mm
Saddle height: 721mm
These are measured from my existing Plasma 5 S that has been fitted by a bike fitter and rides OK, although I never feel as stable as my road bike, but guess that's the nature of the beast.
Looking at Canyon geometry charts either a S or M will fit ? What are the benefits of each ? S will give me the 165mm cranks I currently ride. Would M be a more stable ride ? Any other pro/cons for S & M ? bigger internal bladder ? less/more aero ? more cool looking long seat tube on display :) And any steer on front end ? flat or riser base bar etc ?
tyzer,
Yup you'd fit on both a small and medium. I'm going to put up a specific area of the bike and put some detial into 'em and you can determin what matters to you and how that might become a pro or a con to the size.
Seat Post - if you get the small there will be two bosses exposed behind the post and you could then potentailly use Canyon's oem behind-the-post water bottle holder. If you get the meidum there won't be much post exposed (aesthetics?) and one of those bosses will be burried in the frame so you if you wanted to run bottles behind the seat you'd use one of the myrid of saddle rail mounted bottle holders.
Aerobar riser - if you got the small you'd use the mid riser and not much else to get the pad height right. With the midium you'd use the upper range of the low riser and frankly there's not enough difference here to make anything of it. Logic would say you'd use the flat base bar with both.
Stem length - short stem for both, with the medium you could come shorter 15mm with your Pad X (that should never happen, you're at 425 and based on my mathematical assumpitons you should be riding longer - but, hey, we've only met by text only ESP would be a weaker bike fit communication) and you could go longer out to 465. With the small you could come back 30 or go foward 15mm.
Bike handling - meh... there's nothing drastic here. Both bike sizes, both positions should work well for you.
The other odds and ends... bladders are the same.
There so close that I think the crank length (critical) and the exposed seat post (purely on looks) are enough to tip the scale to the small.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
