Quote:
Hi Ian,
I don’t have a tri bike currently. I do have a Giant TCR in a size XL. I had a specialized Tarmac size 61. I had 2 separate Giant Trinity TT bikes, both size L. My background is road racing and time trialing. I don’t have the reach and stack measurements anymore.
I’m looking to get a Speedmax CF SLX. I’m trying to figure out sizing. I know the value in having it properly fit once purchased. Just trying to get the right frame that I can work with.
If you have any other measurements that I could provide to narrow it up, just let me know. Thank you in advance!
Height: 75inches
Inseam: 35inches
Travis,
Back in the day the only way to get a bike fit was to own a bike. That’s not the case anymore. I hope you’ll allow me to expound for a moment on current, professional bike fitting and the capabilities to “prescribe” a bike to purchase.
Modern, professional, committed bike fitters own tooling specific to their craft. The very best one can do before buying is to find a fitter who is educated in the TT/Tri position, experienced in that position, and who owns a Dynamic Fit Bike (there are only 5 in existence: Purely Custom, Muve, Exit, Guru DFU, and Shimano). You’d go, dressed to ride, ready to work a bit and sweat. The fitter would set up the Dynamic Fit Bike with a saddle right for you, bars that were appropriate, a logical starting crank length and they’d have you hop on and ride.
The fitter would take you through a process and together the two of you would find your optimal position. One that’s comfortable so you can stay in aero for long periods of time, one that’s powerful so your feeling strong in that comfy position, and a position that might sustain comfort & power and reduce some drag.
FROM THAT PRE-FIT PROCESS we’d have two sets of numbers
1) Pad Y and Pad X so we can prescribe the right size frame
and the details of the front end needed.
2) all of your fit coordinates: seat height, set back, cockpit details, pad width, aerobar tilt, etc. etc. etc. The fit is finished even before you own the bike.
If you can’t find that fitter (educated, experienced, and owns/uses a Dynamic Fit Bike) then I can pretty darn close to the Pad Y and Pad X with some body morphology numbers.
So... if you want to get back to me with your location I can see if there's a fitter on my list near you - let's proceed with your morphology 'til then....
I think you're Pad Y is around 675 and your Pad X is roughly 500 - based on that you should get an XL Speedmax SLX with the short stem, flat bar, you'll probably use the low spacer but the bike comes with a slew of spacers and bolt lengths to go up or down to make the pad height perfect, and the medium extension.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
