piratetri wrote:
On the same topic of faster vs slower in the pool. Thoughts on a swimmer who is slower with a pull buoy and paddles (or equal) compared to just normal swimming at the same effort?
What could be potential causes? fixes for those?
It could be several different issues. It could be technical, it could be physical, or it could just be the way you are. Some people are just better at different components of the sport.
Getting more specific...
Causes-
1. Individuals that swim with low stroke rates tend to see more of a drop-off when adding pulling gear. With slower stroke rates, there is a little more space between strokes, which becomes more obvious when the legs aren't there to fill in the gaps. If the slow stroke rate is the result of timing/technical issues, it can be even worse.
2. Individuals that don't have a lot of upper body strength, or swim specific upper body fitness, will struggle. They can use their legs to get through the weak spots. They get exposed.
3. Individuals that have really long arms tend to struggle. It's simply harder for them. The good news is that long levers can create a lot of speed once you have the strength to control them.
4. Individuals that are very good kickers. Take a way the legs, take a way the speed.
5. There could be a technical issue that is made worse by pulling. It could be a timing issue, a body position issue, or an arm action issue
Solutions (numbers relate to causes)-
1. I'm not sure I would actively change this, unless you have a VERY low stroke rate. Changing your basic rhythm can be risky as you may be working against the your body's natural tendencies. It may be helpful to consciously pick up your tempo a bit when pulling. The ability to sustain that tempo will take time develop (see 2). If you are gliding unnecessarily, avoid doing so. Pulling will expose this.
The difference between a naturally lower stroke rate and a stroke rate that is unnaturally low due to technical issues is something that needs to be assessed with video. If it's unnatural, it needs to be fixed.
2. Get stronger out of the water- basic land work. Get stronger in the water by pulling. There are two ways to do so and both can be used. First is simply pull more. Doing more pulling with help in and of itself. The second approach is to use shorter distances and focus on the quality/intensity of your pulling, just like strength training. If you notice the stroke rate is lower, focus on keeping the rate up for short distances. If you notice your stroke counts are much higher, focus on keeping the strokes long and power with a lower stroke count for short distances.
You may intuitively know if you'll be benefit from a shorter or longer approach, or both. Give it a shot.
3. Not much you can change. You'll just have to work more to get stronger to manage the longer lever.
4. Again, just is what it is. It's an explanation, not something you can do much about.
5. If this is the case, you need to address it. It's hard to know what it could be without seeing it.
REMEMBER- with all of this, pulling is a MEANS to an end, and NOT the end in and of itself. It is a TOOL that can be used to help you improve your swimming, but it is not the goal. If you are improving your swimming, but not your pulling, it might not be something to worry about. However, improving your pulling CAN improve your swimming. At the same time, you may find that improving your pulling does NOT improve your
I am not saying that this will happen. I am just cautioning you or anyone reading this that the goal is to improve your swimming, and improving your pulling must support that goal, not replace it. The same goes for ANY supportive training.
I hope that helps!
Andrew
http://www.masteringflow.info http://www.youtube.com/@masteringflow http://www.andrewsheaffcoaching.com/...freestyle-fast-today
