Having a little trouble understanding what this chart is showing. Also, I’m long at the PX frame not the P5D
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [cyclenutnz]
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [whalendds]
whalendds wrote:
Having a little trouble understanding what this chart is showing. Also, I’m long at the PX frame not the P5DWhen at the top of the range the pad stack will be your target 720mm, but if you use the tilt the tilting action actually lowers the front edge of the pads by a bit, so you might only achieve 700mm in the tilted configuration.
Make sense?
E
Each point on the chart is a discrete position that the bars can achieve. I don't really like the coloured regions on the Cervelo site as they don't show the granularity of adjustment.
This is the chart for 0deg tilt, this matches what you see in the calculator on the Cervelo website (I fixed the chart title too)
You can see that the lowest stack of the furthest back position is ~590
Then if we tilt by 15deg (because I've already shown 10)
You can see that the reach doesn't really change but the stack has dropped ~25mm for the highlighted point. It changes less for the more forward settings of the pads.
The target point has a 10mm tolerance circle around it.
This shows that if your stated XY is based on bars that are tilted 15deg, you would not achieve your position on the L. But would be within tolerance on the XL
If your current bars are not tilted at all, you would look at the first example and have the L as an option. In that case the tilted examples just let you know what would happen if you chose to tilt the bars once you got the bike (elbows would lower significantly).
Clear as mud?
Clear as mud?
Hi Eric, some advice needed on which bike and size to go for.
I currently have an Aspire Aeolus, which I've worked out is actually one of many rebadged Dengfu FM086s, which i got 2nd hand when I was first looking for a TT bike, the price was good, it looked big so I went for it. I had a bike fit last autumn and have been really comfortable and fast (for me - FTP currently 282) in races so far this year so I'm thinking about an upgrade.
Having read through quite a chunk of this thread I'm clear that I must be quite scrunched up, so just interested to know your thoughts
Measurements from my bike fit:
Pad X: 660 (top of pad), Pad Y: 425 (rear pad), Pad Z: 150 (inside to inside), Saddle height: 826 (BB centre to 3cm behind tip of saddle)
I have 15 degree spacers angling my pads up a bit
I've measured my current TT bike as Stack: 556, Reach 410
My measurements:
Height:191cm, Inseam 92cm, age 43
There's hopefully a picture attached
Looks like I'm off the chart for normal fit, unless I went for a really small frame, looks like I could do upper left quadrant on a size 54 p5d. But I'm not abnormally inflexible or anything, I can touch my toes, I'm riding a 58cm Scott Addict with only 15mm of spacers. So I suspect I need to rotate myself forwards and lower a bit.
But then I feel good with my current fit, I ran really well off the bike in my first 70.3 a few weeks ago so I'd be happy to recreate what I've got. The bike fitter I saw has fitted some top pros in the UK and I do have space with the pads position to go forwards and lower, so I'm not sure why he wouldn't have done that, or at least mentioned it, if my position is so odd.
Hopefully all that and the photo will prove helpful.
Thanks in advance
Andy
My measurements:
Thanks in advance
Andy
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [billythestick]
billythestick wrote:
Hi Eric, some advice needed on which bike and size to go for. I currently have an Aspire Aeolus, which I've worked out is actually one of many rebadged Dengfu FM086s, which i got 2nd hand when I was first looking for a TT bike, the price was good, it looked big so I went for it. I had a bike fit last autumn and have been really comfortable and fast (for me - FTP currently 282) in races so far this year so I'm thinking about an upgrade.
My measurements:
Thanks in advance
Andy
Hi thanks for reaching out.
You don’t look too terribly scrunched up, or odd, but I do see a bit of “road bike” style in your TT fit, so I could see the whole system moving forward effectively making you longer and in need of more ready.
With a pad stack of 660mm and a pad reach of 425mm you’re a size 54cm P5d, but if you add just 10mm you could hit a size 56cm at that pad stack height. Even so, as it stands you’d have 40mm of reach to play with on the size 54cm.
Make sense?
Eric
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [ericMPro]
Yeah, that's helpful thanks.
I can't find a pad x and y chart for the P Series, what size should I go with on that?
billythestick: Jul 1, 21 9:23
Yeah, that's helpful thanks. I can't find a pad x and y chart for the P Series, what size should I go with on that?
Similar. The P-Series is extremely versatile with the Zipp OEM cockpit.
Have you talked to your fitter about your thoughts?
Eric
What saddle are you using?
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [jimatbeyond]
jimatbeyond wrote:
What saddle are you using?It's an old ISM adamo. No model number on it but probably closest to a PS short one I think
I run my road saddle with about 5degree nose down tilt, this is about the same, should I maybe point that down a bit more to get me rotating forwards?
That’s what he’s intimating. You have an upright pelvis, which is fine in an of itself. If you rotated, because you were more comfortable, you would effectively be longer and thus need more reach.
E
OK, that's really interesting, so much to thjjk about.
I guess the thing that the pad x and y don't rake into account is saddle setback. My bike has the saddle pushed all the way forward but the tip of the saddle is still 4cm behind the bottom bracket.
What's the range of saddle setback on cervelos? If that was 0cm that's 4cm to add onto the pad reach isn't it?
OK, that's really interesting, so much to thjjk about. I guess the thing that the pad x and y don't rake into account is saddle setback. My bike has the saddle pushed all the way forward but the tip of the saddle is still 4cm behind the bottom bracket.
Your actual saddle setback is not that much, mind is 9cm twice yours… however, your hip angle and *effective* saddle setback is way back there because of where and the way in which you sit on your saddle.
All this to say there is nothing wrong with your position or hip angle operationally or ( educated guess) aerodynamically so a 54cm or 56cm P5d will be just fine for you.
Hit me up on PM if you want to chat more or go over to the “Oh My Aching Saddle” thread here on ST.
E
I'm interested in the P105 but not sure what frame size will suit me best. My fit report is included here. Thanks in advance.
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [generals36]
generals36 wrote:
I'm interested in the P105 but not sure what frame size will suit me best. My fit report is included here. Thanks in advance.P Series Shimano 105?
Also, please attach the report.
E
Yes, P105 Shimano 105.
Rather than try to re-attach, including the measurements below:
Saddle Height 700mm w/ a 160 mm crank
Reach: 460mm
Stack: 600mm
Also, I'm 5'6" in height.
Let me know if you need additional information.
Thanks!
Reach: 460mm
Stack: 600mm
Thanks!
Hi All,
I'm riding a 2020 P3X and am looking to upgrade my crankset to a Sram Red Axs power meter (currently riding Shimano Ultegra).
Would anyone know what the standard factory install bottom bracket is on the P3X and what spindle type I would need (DUB or GXP)? I'm pretty sure it is a GXP but wanted to confirm before ordering.
Also considering upgrading to a ceramic speed BB. Any suggestions here as to what model would be best for the P3X?
Thanks!
Thanks!
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [chicoxcrunner]
If you look at your crankset and bottom bracket, you should be able to tell what it is.
The fact that you are currently using an Ultegra crankset means that your bottom bracket is Shimano compatible, and not compatible with any of the SRAM cranksets.
jimatbeyond: Jul 15, 21 21:31
Thank you! I'm not able to tell by looking at the bottom bracket. However, it makes sense that a Sram crankset wouldn't work on a Shimano compatible BB.
You’re currently using a BBRight for Shimano, 24mm on both sides. You need a BBRight for GXP, 24mm drive side and 22mm non-drive side.
They do make shims that might work but it’s not my favorite.
E
E
generals36 wrote:
Yes, P105 Shimano 105. Rather than try to re-attach, including the measurements below:
Reach: 460mm
Stack: 600mm
Thanks!
With a pad stack of 600mm and a pad reach of 460mm you could do well on a 51cm or 54cm. I lean toward the 54cm.
Make sense?
Eric
Re: Official FIT ASSISTANCE for Cervelo TT and Triathlon Bikes [Jmcn]
With a pad stack of 640mm and a pad reach of 440mm I think you’d be perfect on a 54cm P Series.
What size is your P2?
Eric
Pad y 640
Height 180cm
Looking at the p series
Eric
Jmcn wrote:
Pad x 440 Pad y 640
Height 180cm
Hey it is a size 54
Jmcn wrote:
Hey it is a size 54Well done. Yeah, I think a 54cm P Series would also be good.
Eric
What are your thoughts on my position? I have a 110mm stem on at the moment to compensate for the aero bar roll back
