ericMPro wrote:
Hi, thanks for reaching out.
That bike looks to be three sizes too small for you, so a 56cm Cervelo P3 could easily work for you. I’d also go no bigger than 165mm cranks. What you’re describing are classic bad cranks / bad saddle problems and are very fixable.
Just because you’re only doing triathlon on the side doesn’t mean you can’t let the bike do some of the work for you. A proper saddle, crank length, and frame size could do wonders for you.
Make sense?
Eric
Eric! I was able to get my hands on that 2016 Cervelo P3 56CM.
After building it and riding it around for a couple weeks, I thought I had a good position. No pains or anything, which makes me think that I should do what works, but I have a feeling I could be a bit better. My back is naturally rounded a bit, so what you see below is actually comfortable.This is what I looked like before I changed stuff around:
Basically saw that I was reaching a bit so I lowered my saddle a little bit and moved it forward a bit as well. Unfortunately I didn't write down the dimensions before hand.
This is what I look like after:
Again, I feel like my ankle angle is angled too much, but in this position I feel like my knees are going into my stomach a bit too much. On the top of the stroke, I feel like they flare out to the side a bit. While this is not necessarily a bad thing, I think I prefer the taller position because I don't experience this.
As the bike sits now like this, here are the dimensions:
For reference, once again I am 175.25cm tall. Approx 81.28cm inseam.
Thanks for all your help!!
