lenny07 wrote:
Looking at possibly getting Shiv Disc, but I am in between a S and a M. Are there specs on the differences in fluid capacity between the two sizes? I see 1.5L everywhere, but doesn't mention less or more based on size from what I can see. Also I am guessing handling would be affected by size difference. Unfortunately I won't be able to ride each size before deciding, but I am thinking shorter should handle better, or is that backwards?
Capacity is size dependent but it changes about 0.1-0.15L per size
I always advise to Size Up if you can, but the most important consideration in doing so is your saddle height. You can get the same fit on many sizes with the New Shiv Disc but the reservoir system requires you to consider your saddle height.
As for handling, it will depend on your fit. If you have a lot of weight forward of the steering axis (i.e. smaller frame with a lot of reach) the handling is going to be much faster, whereas if you are closer to the steering axis it will be slower....For triathlon, slower is generally better as it takes less energy to maintain a straight line and you arent concerned with ripping apexes on a descent like in a road race.
If you are in between, and your saddle height allows for a MD, that would be my gut recommendation. Of course a good bike fitter should be able to give you the best advice.
