Chris_Mint wrote:
Hey there,
I was wondering if there is a way to adjust a disc wheel within the frame.
I am running the 321 Disc with 26-622 S-Works Turbo tires and it seems that the tire touches the fin/fuelcell when i am going hard on the bikes.
The paint came already a bit off. Is there a way to adjust this or do i simply have to run smaller tires on the back wheel?
THANKS A LOT!!!
That combination should clear. Since its only rubbing on "hard" efforts then it seems like there is clearance, and contact only during flex. This could be possible depending on a lot of factors such as rider weight, bike weight, tire pressure, etc...There is no way to adjust the wheel position since it is thru-axle, but the reservoir position may possibly be able to be tweaked a bit. Are you able to loosen the reservoir, hold it further from the wheel, and then tighten it in place?
teixido wrote:
I'd love an answer too. I'm thinking about cutting the hydration compartment and regluing the whole thing, whatever it takes so I can run my 28's
This would be an extreme measure! 28s are hit or miss depending on the rim and tire. The 321 is going to be better with 26s but i understand the desire for 28s. Before cutting the reservoir, I would slot the attachment hole and slide it up. With an open underside you will collect debris and run the risk of cutting a tire
