mathematics wrote:
This video brought to you by FORM Goggles. Shave seconds off your pace and minutes off your race.
That aside this was a super informative for lactate and swimming. It's fairly straightforward in cycling an running where effort=pace. I'm sure it also has something to do with the density of water. But his chart at the end shows a characteristic inflection point that he marks at 1:15/100, then his lactate more than doubles at 1:11.8/100. I've never seen my lactate spike to that degree in running/cycling. That's like seeing a lactate doubling spike going from 300w to 312w, or going from 6:00/m to 5:45m.
Also Lionel's low HR and low LT2 lactate are massive indicators for long-distance performance. They basically point in the direction of a massive fat burning capacity. Which is interesting given his determination to race 70.3's. I know there's a lot more to it but in isolation this graph shows much more potential for longer distances.
It can double like that in running and cycling as well. the issue is you are using speed in the pool ( very viscos) not power.
So that going from 40 km on the road to 42.2 which takes a lot more power and can send as athletes easily from a 1.6- 3.2 or even higher depending on many induvial factors. that's why someone would want to hold x pace to start x event. And why in Ironman good swimmers surge to get you into the hurt early and hopefully staying there.
The main issue you have to watch for in the water is does the athlete pace well as there is no treadmill control or power meter erg mode.
So if you swim out a 400 m at , 1:08,1:10,1:16,1:16 at what stress level did you test.
Better to have info then no info but pool testing is hard.
Technique will always last longer then energy production. Improve biomechanics, improve performance.
http://Www.anthonytoth.ca, triathletetoth@twitter
