I built a custom SC, but it was a huge pain to build. The frameset is only the frame and fork, base bars were separate, seat post was separate, risers, spacers for the base bar were also separate, aero bars are separate, but I went with an Aerocoach set up anyway. Basically, a lot of the bolts and other proprietary bits are separate orders, and there isn’t a list of what comes with the bars and frame, so you have to use the parts list, and even that doesn’t give you a list of what is or isn’t included.
I started the build on April 2022, and didn’t get the frame and bars until December of last year and then a bag of bolts and bits were missing from the base bars…so I couldn’t finish the build for a few weeks. They also don’t explain anywhere that the length of bolt for the base tower is dependent on the height of the base tower you use and the risers / spacers used with the tower. For example, if you use a 15mm tower with 20mm of spacers, you need a longer set of bolts than a 45mm tower with 5mm of spacers. Yeah…that’s not confusing at all. I ended up at the hardware store to source bolts (offset sizes) for the build.
I finally got the thing built, and it is an amazing bike, it’s fast, and surprisingly compliant and handles well. I don’t regret the purchase, but Trek needs to get their mess together because even the Trek store was lost with this one.
