Got my new 2023 SC, and I have a weird issue.
Taking the back wheel On and Off does NOT seem right - it interferes bad with the top pulley wheel due to clearance issue
What am I missing, or is this a frame/derailleur hanger design issue (or manufacturing issue on a component)?
Details:
- Medium frame
- Shimano 12 speed (Ultegra derailleur)
- Standard Pro 51 Bontrager wheel, 25 mm Conti 5000 tire
I am going into the smallest cog in the back.
At first the wheel comes out nice.. Derailleur swings back smoothly till it reaches the end stop.
but you reach a point where the small cog with the chain binds completely to pass the top pulley wheel. Puts pressure on the derailleur (it can't swing back further, hard stop) and it starts deflecting.
On the front, the 25 mm tire is jammed in the widest part of the opening (problem would be worse with a 28mm tire!)
Only way to remove is put more force, bends the derailleur assembly and what it is attached too slightly then it releases...
Note: Normally I do hold the read derailleur w one hand, rotating it all the way back too to help, but in below picture I needed a hand to take the picture - still the RD is rotated as far back as it will, hard stop.
But in this process, the inside of the derailleur cage also gets stuck between 2 cogs, scratching it (paint all scratched up from taking the wheel off 2-3 times only!);
I checked the derailleur hanger - it had a little of play (maybe from taking the wheel OFF and On a couple of times!); I tightened again (and found out the 2 mini screws had the hex stripped or about to..
The problem would be avoided (or be less) if the Shimano bracket was not resting on the stopper of the hanger (green box above) and instead tightened while being rotated back a bit (yellow arrow) but checking the Shimano manual - and common sense) - the correct way to install is resting on the stop of the hanger.
Only other way I see, is deflating the tire every time - but if working with tubeless, I assuming that replacing the air each time would make the sealant go bad a lot quicker... I originally thought I would run this bike w 28mm on the rear, at least in training - especially with the 23mm internal width stock wheels - but the situation above alone is a reason to not go higher than 23mm tires.
What am I misssing? Or am I not the only one? Can't imagine it is supposed to be like that. I do not have this issue on my older 11 speed Madone with 8000 RD.
Hoping it's something stupid..
T. Guertin / Spocket
Details:
- Medium frame
