IamSpartacus wrote:
Nope that’s the sucky thing. Ordering p1, You need to specify the tower height. You do get two 5mm spacers as well as the angled ones. But If you stuff up the tower height you need to order different ones again. They are like $30us each or something…. But! You don’t get the bolts with them. Typical trek….. you think you can order a few bolts right ? Nope. They come in a case and you get all the different bolt lengths as one order. Atleat that’s what the website says. And those case of bolts (of which you only need 4 for your towers) are around $300 aud, unsure of the us price. It’s ridiculous. The towers you buy if you get that wrong should come with correct length bolts. You may get lucky with your trek Shop and they may have some lying around. But yeh, you want to get the tower height right first go.
Are you sure about this? I will have to look at my extra bolts when I get home. The bolts that mount the tower bases from the bottom of the basebar are all the same size iirc regardless of tower base height. My p1 order came with several different size bolts to mount the spacers/tower toppers. Unlike previous models, the bolts do not go through the entire tower base. There are threads at the bottom of the tower base and top of the tower base for fastening. I have two 7 deg wedges mounted and needed one of the longer bolts to ensure enough thread engagement.
Edit: just looked at the service manual. The underside bolt is M6x20mm and there are 3 different lengths for the top side (25mm, 35mm, 45mm). All of those bolts should have came with a P1.
blog
